Sunroof doesn't open.
My sunroof dowsn't open when I press the button, but still opens manually with the spinning handle. HHow do I trouble shoot through this. Could it be an electrical problem?
hi
Re: Sunroof doesn't open.
Does the drive motor run?
- TonioDLR
Yeah, does it make anykind of sound. A humm, buzz, or a click besides the button click?
![Image](http://www.geocities.com/toniodlr/ivana_mini.jpg)
Before you criticize someone, you should drive a mile in their wheels. That way, when you criticize them, you're a mile away and you have their wheels.
Did you check the fuse?
Hey my car does the same thing. There's a plastic gear they call the worm gear and it needs to be replaced. I think I'll wait to summer. Madjeep
