GAS MILEAGE
Locked
mitmaks
GAS MILEAGE
Post by mitmaks »
hey i own a limited edition mx-3 GS but my '88 civic Dx got a problem with gas, i get only about 200 miles from a tank of gas...i think its fuel injector problem, sometimes when i start it, exhaust fumes smell like gas, and at stop lights idle gets high then drops, any info how i fix that sucker.<BR>thankx
COMPACT Gladiator
Re: GAS MILEAGE
Post by COMPACT Gladiator »
i think you should get your injectors check...that can be a good start!
Bri94GS
Re: GAS MILEAGE
Post by Bri94GS »
here's a few things it might be:<P>1. Water Pump<BR>2. TPS (Throttle position sensor)<BR>3. o2 sensor<BR>4. Air filter<BR>5. Spark plugs/wires<P><BR>Are you sure the '88 Honda is fuel injected? I think some of those still had carbs in em. If it has a carb, get that checked out too..maybe something is clogged or causing it to run rich
~Bri - Morph860@aol.com
'94 MX-3 GS (FOR SALE!)
'04 Mazda 3s 5-door
zoom-zoom
mitmaks
Re: GAS MILEAGE
Post by mitmaks »
ya mine if PFI programmed fuel injection...it has a newer style motor too..like '95 civics do, maybe previous owner swapped it or something. may it be due to absense of air filter at all..?
David Coleman
Re: GAS MILEAGE
Post by David Coleman »
To the Off Topic Forum...You guys know better... :roll:
David Coleman
Locked
