some mechanical advice :)
Okay, Im hoping someone has had this problem before. <P>My car makes a whine or squeal sound every time the wheel spins...and when I accelerate it increases... My guess is the brakes...which I think I can afford...but has this happend to anyone else. I even parked the car in a steep driveway and rolled it backwards with no engine to see if it was the engine at all..and it still made the noise...<BR>any ideas? <P>Thanks,<BR>Tom
Tom Alexander
Re: some mechanical advice :)
The sound you hear is normal, it tell you that your brakes pads need to be replaced soon!<P> ![Cool :cool:](./images/smilies/icon_cool.gif)
Friends don't let friends drive stock.
thanks bro,<P>it went away after a good hour of highway driving. I am going to get my brakes checked out soon !
Tom Alexander
I had that problem my front brake was making a squealing noise. The heat shield was rubbing against the disk... so I just pulled it back and it's been okay ever since.<BR>hope this helps
![Image](http://images.cardomain.com/member_img_a/257000-257999/257678_6_full.jpg)
