V6 knocking from the head
Posted: August 8th, 2001, 6:49 pm
by J. Carlsson
Thinking of buying a 323F y 95 (lantis model).<BR>the car has a 2.0 l V6 and 146 or 147 hp. And should be the same as the on in the MX3 (+0.2l).<BR>The kocking I heard seams to come from the head, and the engine should have hydralic valves what could this be and how expensive?<BR>The car had been standing for a cuple of weeks, and the milage is 75 000 miles(120 000 km). Last indicated service was made at 90 000km.<BR>When should the belt be changed?<BR>Whats els should I lookout for?<P>The car did drive god with a god pull from the engine (cupling was sliding a bit) <BR> <BR>Thanks <BR>J C<BR>
Re: V6 knocking from the head
Posted: August 10th, 2001, 2:56 am
by kick_n_canadian
hey there,<BR>I own a 92 MX-3 GS. I not long ago had a similar problem, there was short quick knocks comming from the heads, and small vibrations. The knocking only lasted about 2-3 minutes, then it disipated. I took it in to have it looked at, and the compression test failed... boooo... $5000 CANADIAN later it runs like new, as it needed to be completely overhauled. There is a major service to almost all mazda cars at 96,0000Km at witch time, the timming belt needs to be replaced, the cost $900 CAN. This is likely your only problem, however check the compression that vibration in my head was likely either the timming belt or the valve seals. <P>By the way to all MX-3 owners, keep them going strong. I just invested over $7000 in the last 2 weeks to keep mine for another 200,000Km. And believe me there is major power behind this car, even after a complete rebuild. Money is always well spent on the precid.
Posted: August 14th, 2001, 8:12 pm
by jfbourgault
I had a similar problem about 2 months ago caused by low oil level , The car was knocking at startup and after it had run a little while, I had forgotten to look at my oil level for the last 2 weeks, Horror, it was missing 1½ liter of oil. the noise was coming from the rear cylinder head, IT immediatly stopped after I added some oil. Be very carefull with that, It could damage or burn your valve seals. luckily, nothing happenned to mine ( I think so)
Posted: August 22nd, 2001, 12:24 am
by Joksta69
just had that problem, get the half-shafts checkd make sure the boot around it is sealed if not that is your problem it cost 140.00 us dollars
Posted: August 23rd, 2001, 1:38 pm
by GEN-MX
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by kick_n_canadian:<BR><B>hey there,<BR>I own a 92 MX-3 GS. I not long ago had a similar problem, there was short quick knocks comming from the heads, and small vibrations. The knocking only lasted about 2-3 minutes, then it disipated. I took it in to have it looked at, and the compression test failed... boooo... $5000 CANADIAN later it runs like new, as it needed to be completely overhauled. There is a major service to almost all mazda cars at 96,0000Km at witch time, the timming belt needs to be replaced, the cost $900 CAN. This is likely your only problem, however check the compression that vibration in my head was likely either the timming belt or the valve seals. <P>By the way to all MX-3 owners, keep them going strong. I just invested over $7000 in the last 2 weeks to keep mine for another 200,000Km. And believe me there is major power behind this car, even after a complete rebuild. Money is always well spent on the precid.</B><HR></BLOCKQUOTE><P>Hey Kick' n I had the same prob as you. Driving on the highway, cylinder valve burnt out...No compression on comp. test.
i.e. $3000 later, all new parts, runs like new again!<BR>Props to the Precidia!<P><P>------------------<BR>Marc 93MX3RS
