Help needed
- SE-Man
Help needed
I was driving one day and my engine started running funny, so i decided to get off the hwy and check it out. when i got off it stalled as soon as the RPMs droped. Now the car will only start if the gas peddle is flored and it dies as soon as the RPMs drop. Has anyone had this problem or know what is causing it? 93SE 1.8L<P>------------------<BR>Thanks,<BR>Teri<BR>'93 MX-3 SE
Re: Help needed
I know sod all, but...<BR>I had a similar problem, which appeared without warning, unever running... turned out to be the HT leads, and recent I had the air intake hose split, unever idleing, and a couple of stalls.<BR>It seems both are common problems...<P>HTH
Re: Help needed
Hey SE man.<P>You might wanna try to hook up with ProbesNW there in Washington. I know a few of the guys work at Fort Lewis. A certain guy out there has a 93 Turbo'd PGT with 235wheel HP!<BR> <A HREF="http://www.ProbesNW.net" TARGET=_blank>www.ProbesNW.net</A> <P>Tell 'em Dave Coleman sent ya
<P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
![Image](http://www.mx-3.com/ubb/wink.gif)
David Coleman
Re: Help needed
Teri, have you had the pleasure of replacing your distributor yet? Sounds kind of similar to what was happening to me a few months ago. Hey, let me know when you're going to some meets around here in WA and we'll cruise together!<P>Casey
Casey Guthrie
[email]goesfast@theraces.com" target="_blank[/email]
Re: Help needed
Yo Se-Man,<BR> that exact s--- is happening to me right now! i dont kno wut to do. it stalls sometimes when its just sitting. So if someone told you wut it is can u tell me???<BR>that would be str8!
Re: Help needed
Deano96GS<P>HT stands for "High Tension", another name for the lead from the coil to the center connection to your distributor. This has been erroneously applied to ALL ignition wires but should only refer to wire from coil to distributor.
