Overheating
Overheating
My 92 mx-3 v6 gs is over heating, i have switched the water pump, the thermostat, the radiator hose, and the radiator caps, it over heats unmless i put water in it constantly, if any one knows anything i can check, or what has happened to theirs e mail me or post me a message
Re: Overheating
hey <P>I had a similar problem. I put up with it for a while but it got considerably worse, to the stage that I could see water running out of my radiator as I poured it in the top. Turned our that the leak was where the main hose fed into the radiator. The connection actually completely broke when I pressure checked the system. It was repaired by having a new side welded onto the radiator. I havnt heard of this happening to anyone else but this was my experience<P>J.
Re: Overheating
check your oil and make sure you water isnt going into the oil and also check the exhaust if you have water in either your have a bad head or headgasket, if not check the radiator for holes cracks even it may be partly blocked inside <P>------------------<BR>92 MX-3 GS<BR>brillant biege<BR> spawn_46375@yahoo.com
92 MX-3 GS<BR>brillant biege<BR>www.angelfire.com/in3/spawn46375<BR> spawn_46375@yahoo.com
Re: Overheating
have you had a flush ? perhaps you have some air in the coolant and thats why its not cooling properly.<BR>try using a bottle of red line water wetter<BR>it helps cool the engine<P>------------------<BR>All motor 176WHP Mx3 - Dyno test coming in April
