OverHeating
- Franko
OverHeating
I got stuck in the ---damn snow like an hour ago and a bunch of snow got up in the engine bay, stopping the fans from spinning. I got a 4 cylander engine and the temperature gauge was all the way up but I didnt notice.. As soon as I saw what was going on I got out and fixed it.. but now I am concerned about the heat being up so high.. Do you think that I could have caused any damage to the engine? I hope not.. it dosent seem to be damaged but what do you all think?
![Image](http://i17.tinypic.com/30idc09.jpg)
Re: OverHeating
i think you should be fine. just check all your coolant hoses, radiator cap, and coolant. you should also make sure the fans still work. also keep an eye on your temp gauge. if it goes up again then take it to your mechanic
