front clips
Eunos 30X/Presso/Autozam AZ-3 Discussions
nickmx3
front clips
Post by nickmx3 »
if i were to get a front clip to do my bpt swap into the az3 will it be a direct swap what would i have to look at getting
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
Sam Baker
Post by Sam Baker »
ax3 is 4cyl right? well it should bolt right up, but most people say you should use a Protege/323 transmission and axles. you will also need parts like the ECU, and turbo gauges.
but hey i have a question for you! can you get front clips of Autozam AZ3s?? like the dashboard to the front bumper? i'm lookin for a front clip (right hand drive) for a conversion hehe
92 Autozam AZ3
nicksmx3
Post by nicksmx3 »
hey! you stole my member name! lol
DavidOS
Post by DavidOS »
and a good wiring harness!!!!
Return to “Eunos 30X/Presso/Autozam AZ-3”
