manuals
manuals
am looking for a workshop manual for a 1995 az3 does anyone know where online i can find one, also i just changed my shocks and now hear a squeaking kind of sound like a bushing going bad anyone have an idea as to whats causing this the noise comes from around the shock area
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
Re: manuals
Not 100% sure coz depending on the situation and sometimes ya gotta hear an' see to judge. but I also recently threw in some tokicos all around and it could possibly be; specially if the noise is coming from the top, that the end of your shock is hitting the actual shock mounts or you know how the seat belt at the back connects to the actual mounts. So most likely the end of your shock rod is just barely touching the mounts or the seat belt mount making that noise. Open it up(the speackers) and just press down with your ands at the back and see if the shock rod is touching anything from the top. If it is from the bottom it could be anything from coils not perfectly setting in to some barings down there... just and see and test.
Re: manuals
thank that was basically the prob solved it saturday
