Re: Differences?
Eunos 30X/Presso/Autozam AZ-3 Discussions
argh
Re: Differences?
Post by argh »
The AZ-3 is a Jap import only. It came in manual or automatic, with slightly different styling to its UK/US counterpart.<P>With my limited knowledge of the other MX-3 models, the AZ-3 seems to have greater similarities to the 1.8 model chassis, rather than the 1.6 model. <P>The engine is a 1498cc 4cyl twin-cam (overhead) DOHC with EFI. As far as I can tell, the engine is the j-spec B5-ZE (I believe the ZE represents performance model). <P>This particular engine is quite difficult to find out about (most of the info I could find is Japanese). Mazda shops here in Ireland are very unhelpful and info is scarce. If anybody has more on this subject or regarding transmission (I'm guessing its F25M-R) etc., please help out!<P>The engine puts out an impressive 115bhp @ 6500rpm (far higher than the 1.6 model). The car comes with all extra's except s/r. Brakes are front disks, back drums (ABS on some later models).<P>I've heard a number of negative remarks about the AZ-3. This is mostly due to the fact that they are not well known. This leads to lot of confusion and rediculous prices being asked for spare or replacement parts (many are interchangable across the model range).<P>I'm an AZ-3 owner myself - all in all, I reckon this is the most kick-a-- 1.5 Mazda ever built!
David Coleman
Re: Re: Differences?
Post by David Coleman »
Thanks for the info!<P>Your intelegent addition to the board is very welcome!<P>------------------<BR><B><I>David Coleman</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><A HREF="http://www.highlandsun.com/hyc/sae920677/" TARGET=_blank><I>V6 engine info</I></A> | <A HREF="http://www.bradbury.cwc.net/probemx/index.htm" TARGET=_blank>KL FAQ</A> | <I><A HREF="http://www.brownsword.ca/Probe.html" TARGET=_blank>ECU reprogramming</A></I> | <A HREF="http://members.home.net/tekguy/" TARGET=_blank>K series Image cache</A> | <I><A HREF="http://archive.probetalk.com/cgi-bin/se ... tion=intro" TARGET=_blank>Probetalk Archive Search</A></I></B><BR><B>Support OPEC: Buy an SUV</B>
David Coleman
nickmx3
Post by nickmx3 »
okay the az3 (autozam)
ec5sa f11 model
j-spec
b5-ze 1498cc engine
mt 120 bhp
at 115 bhp
the gear box am not too sure about the series
the label on my both boxes are damaged
however the original box has casted in it f520, f5d2 and on the label f5d3 and kd also on the label, the second box that i currently use has the kd and f markings but are slightly different cant tell you exactly what they are because i cant remember, but i think that this box came from a 323 or protege not too sure about the protege could be wrong.
1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
AZ-3,1498cc,UK
Post by AZ-3,1498cc,UK »
The Autozam AZ-3 began production in 1991 with the 1.5 16 valve DOHC engine. In 1993 the was 1.8 V6 24 valve DOHC also used in the Autozam AZ-3 with both models being produced at same time.
The Eunos Presso was available in 1993 with the 1.8 V6 24 valve DOHC and the 1.5 16 valve DOHC engine.
In both the Presso and the AZ-3 the 1.6 litre versions were never produced.
V6 MX-3, Black, 17" gunmetal chromes with 205/40/17.
Now gone: Autozam AZ-3(Jap spec MX-3). 91, 1498cc DOHC 120bhp as standard. Manual, A.C, 17" black chromes with 205/40/17. Stainless Steel Exhaust,Pipercross Filter, Eco-tek valve, Strut brace, Racing steering wheel.
Return to “Eunos 30X/Presso/Autozam AZ-3”
