Wiring Up
Wiring Up
Got a Blaupunkt Hawai the other day with a seperate 5 disc in dash autochanger(pics soon). No matter what I do the wiring is wrong when I do it like the book says I blow my parking lights. So at the moment it's hooked up to the ignition which is really annoying. Anyone had this problem or have any ideas on how to sort it.
'92 MX3 1.8 V6
G-MAX 40mm lowering springs
'91 AZ3 1.5 35mm drop +V6 stryt brace.
- monty73741
Re: Wiring Up
sounds like a ground....
check your wirering.....
did you splice or use a plug...to install it
jasn
jasn
Jason Danaher
Please Help Support MX-3.com
Re: Wiring Up
I always use plugs and solder, some good habits I picked up rebuilding bikes. If it's the ground I'm in for trouble, my ashtray lights got a mind of it's own, I thought the bulb was blown for the last week but it just came on again.(lol)
'92 MX3 1.8 V6
