wiring alarm to parking lights
marshmallow15
just got my commando alarm and power lock kits yesterday. almost everything is hooked up except for the parking light relay. where can i find the wire for this? can i simply hook up a wire to the alarm module and to the hazard fuse and be done with it?
- team slideways
- team slideways
Da_Wiggy
Re: wiring alarm to parking lights
YEAR: 1992 MAKE: Mazda MODEL: MX-3 STYLE: <p>| ITEM | WIRE COLOR |POL | WIRE LOCATION |
| 12V |black | + |ignition harness |
| STARTER |black/blue | + |ignition harness |
| IGNITION |blue | + |ignition harness |
| ACCESSORY |black/red | + |ignition harness |
| POWER LOCK |actuator | |drivers door |
| POWER UNLOCK |actuator | |drivers door |
| PARKING LIGHTS + |red/black | |dimmer control switch |
| PARKING LIGHTS - |green | |steering column |
| HEADLIGHTS |blue/yellow | - |steering column |
| DOOR TRIGGER |red/white | - |3 pin plug above fuse |
| TRUNK/HATCH PIN |red | - |at switch or light |
| TACHOMETER |yellow/blue | |at distributor |
| BRAKE WIRE |green | + |brake switch |
| HORN TRIGGER |grn/red or grn/blk | - |steering column |
| WIPERS |blue/white | + |steering column |
| LF WINDOW UP/DOWN |red/blk red/grn | A |in drivers door |
| RF WINDOW UP/DOWN |red/wht blk/blu | A |in drivers door or dkp
marshmallow15
cool thanks a lot. wouldn't the 12v ignition wire be in the steering column?
- team slideways
- team slideways
Da_Wiggy
yeah dude the ignition harness is in the steering column. The 5 or so thicker gauge wires that run in your column to your key cylender is called an ignition harness. Any other questions I can help you with?
