How much is a decent alarm system ... with...
Car Stereo/Alarm Discussions
Tyler17rose
Post by Tyler17rose »
I am planning on getting a alarm for my mx-3 with keyless entry. I got a quote today and this is canadian funds ... $365 for everything instaled along with a drivers side actualtor for the keyless entry. Plus tax. <p>Is this a good price? Should i shop around more? Oh and if it helps its the Clifford Matrix 2 alarm.
Mods:
mzdspd
Re: How much is a decent alarm system ... with...
Post by mzdspd »
sounds good but what kind? what features?
Tyler17rose
Ok for the people that need more information:<p>Its the Clifford "Matrix 2" with options:<p>- Two 4-button transmitters
- 3 Receiver Channels
- XHF
- PC/Bitwriter Programmable
- Failsafe Starter Kill
- Power Door Locks
- Power Trunk Ch/2 Output
- DomeLight Supervison
- Parking Light Flash Built in polarity outputs
- 5 Zones
- Ghost Switch
- Owner Recognition
- Rapid Resume Logic <p>
Thats all the stuff the web site says.
Mods:
mzdspd
Post by mzdspd »
sounds about right my friend got a viper installed a few days ago with the same exact features and it was 350 installed so thats about right
avio
Post by avio »
yeah it's just about right cause i got mine for 300$ :p do u possibly know how much they are charging for the installation? cause i got one for my civic and it's giving me a hell of a time trying to install it ! :mad:
sep42
Post by sep42 »
I dont know if you have beamriders (http://www.beamriders.com) on the east coast, but they have a special on. <p>$189 marksman m3 (magnadyne.com) 118db siren, LED, dual stage impact, warning+trigger, 1kill switch- $25 extra kill, $200 +optional pager, keyless entry is extra about $80 extra, flashing lights extra $20. <p>they use black cables and hide everything behind the firewall. They spend 3.5hrs on the install instead of 2hrs or 30min that Futureshop spends.
There is no install charge, it's all included in the price+tax.
http://www.nerdinthebox.com <- cheap domains, web hosting and other network services.
Paragon
Post by Paragon »
i'd go with that clifford setup. DEI alarms are great products, with a ton of room for expansion. that's a pretty good deal for what you're getting. i got a viper 600 with keyless entry (both doors, had to add power locks), trunk/hood pins, and other little features. probably would have cost about 400 if i hadn't worked at the stereo shop and installed it myself
jpwmx3
Post by jpwmx3 »
The Avital 2100 <p>2nd Channel for Trunk Release Yes
Active/Passive Arming Yes
Dome light Supervision Yes
Included In Box Alarm, Remotes, Manual
Number of Channels 3
Number of Remotes 2
Park Lamp Flash (relay Included) Yes
Power Door Lock Control Yes
Remote Code Hopping Yes
Shock Sensor Type Dual Zone
Silent Arm/Disarm Yes
Siren Type 6 Tone 120 db
Starter Disable (Included) Yes
FEATURES:<p>• 2 3-button transmitters <p>• 3 Receiver Channels <p>• Parking Light Flash Relay <p>• Starter Kill / On Board <p>• Power Door Locks <p>• Dual Zone Shock Sensor <p>• Multiplexed Sensor Input <p>• Six Tone Siren <p>• Passive / Active Mode <p>• Chirps On / Off <p>• Ignition Control Door Locks On /Off <p>• Passive Lock On / Off <p>• 0.8 / 3.5 sec. Door Lock Output <p>• Single / Dual Door Lock Pulse <p>• Stealth Coding On / Off<p>Is this one any good.? It's $200 installed at futureshop
Da_Wiggy
Post by Da_Wiggy »
personaly I would stay away from clifford (you going through pearl?) I find that they are not user friendly at all. In my car I run an alpine sec-8063(top of the line) which I absolutly love but alpine is no longer distributed in canada (or at least not in ottawa) If I were you I would look into viper or python. Both should be around the same price as the clifford (depending where you go.
Return to “Car Stereo/Alarm”
