Car Alarm Install
Car Alarm Install
Hey<BR>Does anyone know how difficult it is to install your own Car Alarm? I just purchased one with Remote Start. Any hints?
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- neverenuff
Re: Car Alarm Install
Take it to a shop and get it done if you have no idea on how to do it remote start can be tricky and if instaled wrong you could cause some serious damage!!!!!
I just got a new alarm installed by a shop. If you let a shop do it, they have the experience to tackle some unforeseen problems you may run into. And they know some tips and tricks to install it better. Given that this is for the security of your vehicle, I would suggest letting a shop do it if you're not too sure about it yourself. You wouldn't want to short anything out and cause yourself more problems. <P>Plus the shop that I went to, they give you a lifetime warranty on the install and on the alarm itself. So that's very reassuring as well.
Yah your right the shop is the best bet, You can't beat a life time warranty on labour. The alarm is really simple but the car starter is the b----, especialy if you have a standard trany. Take it in pay the money or you can waste, well probably a good day of your life and the chance of wrecking something, why risk it? Unless you kind of know what your doing and you feel lucky that day. Good luck!
LIFE IS A HIGHWAY I WANT TO DRIVE IT ALL NIGHT LONG!
