Sound fades.
Posted: February 26th, 2002, 1:50 am
by A.S.
My system's been acting up lately: the sound kinda goes up and fades avery few seconds, almost like someone is playing with the bass and the treble. what gives?
Re: Sound fades.
Posted: February 26th, 2002, 11:47 am
by neverenuff
hey,<BR>well is it fadeing or cuttin out if it's cuttin out i'd say amp prob if it's fading id say headunit prob.if you have another headunit swap it for a littlewhile see what happens!!!
Re: Sound fades.
Posted: February 26th, 2002, 12:59 pm
by Sonicxtacy02
i would check your speaker connections, one may be loose and causing the speaker to turn on and off while driving.
Re: Sound fades.
Posted: February 27th, 2002, 2:18 am
by A.S.
The sound doesnt completely cut out, Its actually pretty loud, Only the bass seems to fade and come back within 5 second intervals.
Re: Sound fades.
Posted: February 27th, 2002, 11:28 am
by neverenuff
OK WELL IT'S ONLY THE BASS RIGHT.DOES IT GOO OUT OR JUST GET LOW?FIRST I WOULD CHECK HOW HOT THE AMP IS GETTING THEN I WOULD CHECK TO MEKE SURE MY SUB CONNECTION WAS OK NOT JUST FROM THE BOX TO THE AMP BUT THE SPEAKERS TO THE BOX SOMETIMES IF YOU DONT HAVE A SOLID CONNECTION THE WIRE CAN COME LOOSE WITH A GOOD BASS NOTE AND IF LOOSE ENOUGH IT CAN TOUCH THE OTHER LEAD MAKING THAT CHANEL GO OUT LEAVING ONLY ONE SPEAKER WORKING WICH COULD SOUND LIKE A FADE .START THERE IF NOT THE PROB THEN LET ME KNOW AND WE CAN TRY TO GO A STEP FURTHER.<BR> ANY OTHER ? OR ANYTHING I CAN HELP WITH HIT ME UP!!<BR> LATER
Re: Sound fades.
Posted: February 27th, 2002, 2:42 pm
by A.S.
I'll check all the wiring starting from the subs. <BR>Thank bro.
