Bazooka EL1204
Bazooka EL1204
hey i just picked up 2 of these and im running a Bazooka EL1500 amp to em. wired in parallel cuz its a 1 channel amp. they hit real nice but there is alot of rattle in the trunk. i know your supoposed to use dynamat to stop the rattle but (forgiv=e me im an idiot) i dont know where to put the stuff. as soon as i found out where to put the dynamat im gonna go get some and its gonna be pretty damn nice. also does anyhoine have these? what kind of box did you put em in?
<A HREF="http://www.geocities.com/mail_cory_here" TARGET=_blank>Codenes Car</A>
Re: Bazooka EL1204
You stick it to the meatel under the carpet. Or you can just have your car rhino lined.. Thats what I am gonna do.. [img]shrug.gif"%20border="0[/img]
MrsOzx<p>buh-bye........
Giavonni Perelli
Giavonni Perelli
Re: Bazooka EL1204
rhino lined? [img]shrug.gif"%20border="0[/img]
loudsubz
Re: Bazooka EL1204
Dynamat is expensive for what it does. There are alot other cheaper sound deadners out there.<BR> <A HREF="http://www.b-quiet.com" TARGET=_blank>www.b-quiet.com</A> is an alternative. Brown bread is great too. I woulnd't do the rino liner stuff, it will stink up your car and is not really meant to be used inside the trunk of a car.<P>For the sound deadner, just apply it to the trunk lid and inside of the trunk, around the spare tire well and any picec of metal that seems thin and rattles.<P>What the deadner does is add mass to the metal making it less prone to rattling.
- neverenuff
Re: Bazooka EL1204
HEY GUY'S<BR> WELL #1 DYNAMAT IS VERY EXPENSIVE & IT GOES ON THE INER BODY OF THE CAR WITCH MEANS YOU'R GOING TO NEED ALOT.RINO LINING IS EXPENSIVE TO THAT IS SPRAYED ON YHE CAR IT'S REALY USED ON PICKUP TRUCKS FOR THE BED.NOW AS FOR THE EL1204 I HAVE A PAIR IN MY OTHER CAR,IT'S A 99 COUGER IT'S A HATCH TO ANYHOW I HAVE THEM IN A SEALD PREFAB BOX THEY SOUND GOOD THEY HAVE A QUICK RESPONCE RATE.ALSO DYNAMATE CAN WEIGH THE CAR DOWN TOO IF YOU LINE THE WHOLE CAR.<p>[ February 18, 2002: Message edited by: NEVER ENUFF CUSTOMS ]
Sonicxtacy02
Re: Bazooka EL1204
i have these speakers also i believe.. i really dont know as they were given to me. I have 12" bazookas something-or-others with the little coolant thing on the back. Anyways, i'm currently running them on a 500 watt rms amp. What is the power rating on these? Also, has anyone used these with a bandpass or a Q logic box. The box i have now weighs 50 lbs WITHOUT the speakers.
Shaun Newman
Re: Bazooka EL1204
the 1204 are rated at 250 rms w/out the cooling and 350 rms with the cooling (bazzoka CHIL pac i think its called?). im currently running them in parallel with a 600WRMS bazzoka amp so im giving them 300rms a piece at 2 ohm. they sound real nice. i guess im gonna try that b-quiet stuff. its all metal in my trunk already cuz i had to remove the plastic pieces so i could undo the taillights to put my new body kit on. i guess ill run b-quiet all alon the walls anf floor of my trunk. ill let you know how it turns out.
Crazed8056
Re: Bazooka EL1204
Hey Codene,<P>Buzz Off alarms in Tampa carries dynamat. I think its off of Dale Mabry.. near the stadium..
Re: Bazooka EL1204
i can get it for about $99 for 20 sq. ft. thatll do my whole car but its alot of money for sound deadener
loudsubz
Re: Bazooka EL1204
for $99 u can get 35 sq ft of brown bread which is better than dynomat.
Re: Bazooka EL1204
how much would i need to do allo my walls and my floor inside my trunk?
Re: Bazooka EL1204
what about that liquid stuff? does that work well?
Re: Bazooka EL1204
Rhino lining is what they put into truck beds to protect it from corosion and dammage. They spray it on and it is up to 2 inches thick and works alot better that dynomat. I had my Mustang done and loved it.
Giavonni Perelli
Giavonni Perelli
- neverenuff
Re: Bazooka EL1204
well fellas,<BR>like i said before rino lining is for trucks,it also smells the car up & you will spend twice the money for it i would'nt put it in my car, not to knock anybody but sorry.
