Mounting Amp/subwoofer more securely
Car Stereo/Alarm Discussions
Andrew_Pakula
Post by Andrew_Pakula »
A little while ago I posted how my car was broken into and my Amp and Subwoofer stolen, <A HREF="http://www.mx-3.com/cgi-bin/ultimatebb. ... 8&t=000149" TARGET=_blank>here is the link</A> if you want to read about it.<P>My question is when I go to replace the amp and subwoofer in the spring, can anyone suggest a better way or better spot to mount the amp that would make it more difficult for someone to steal.<P>They only took the amp and subwoofer because basically they just unplugged and dissconnected it. They left the CD-changer because it was under the passenger seat and the face plate was not there so they left that as well.<P>Would mounting the Amp under the drivers seat be a better idea?<P>As for the Subwoofer box, any ideas how I could make it more difficult for them to just dissconnect it?
loudsubz
Re: Mounting Amp/subwoofer more securely
Post by loudsubz »
when you mount the amp again make some covers for it to blend in with the stock carpet or soemthing. Also for bolts or screws use a different style, like hex heard or bolts and bolt it down good.<P>I know theres security screws u can buy that need a special driver to put them in. :)
Andrew_Pakula
Maybe I'll bolt it down then because it was mounted behind the back seat before, even if I used security screws I'm sure they could ripp it off if they wanted to since it's only the back seat.
-=deathtrap-mx3=-
Post by -=deathtrap-mx3=- »
if you want those sec. screws [irl]http://www.selectproducts.com[/url] has them. you might be able to pick up just at couple ur local shop. hex;s are the best suggestion. if you bolt ur box onto ur car, most insurance companies will cover it if its stolen again.
Looking for a 94+GS for KL-ZE fun :)
02 Protege DX Retired
93 MX-3 RS Gone But Not Forgotten
Return to “Car Stereo/Alarm”
