speakerwire wiring to doors
Is there any tips about installing new wires for front speakers, I do not want to make new holes for my car's body. <BR>any tips for rubber joint parts between door <P>If somebody changed already, could you tell me what did you do for these areas.
- monty73741
Re: speakerwire wiring to doors
just take off the door panel and run t he wires throught the stock locations
Jason Danaher
Please Help Support MX-3.com
How about a harness covered by a rubber boot<BR>which find in car body.<BR>(...between door and car body, there is rubber boot protecting wires and holes for these wires but at car body side,<BR>there is a harness attach to the hole, so I can not wire the hole unless I have to do something to that harness or make hole for car body.)<BR>is any body know what I taking about?<P><BR>----OR-----<BR>Yours are different from mine
with the holes, i found it just easier to pull out the lil harnesses under the rubber boot and pullin wire around it and just going around the boot alltogether. Tried through it and it was a pain.
"laziness breeds ingenuity"<BR>93 white bone stock mx-3 GS
if you mess with the boot, be ready for many small cuts on your hands, cause its hard as hell to get off the then get the harness out the first time. Then putting it back in!. Dont get me started
Shaun Newman
I had small plastic plugs on either end on my civic, so i had to take the plugs off and run the wire through without the plugs, was much easier too.
