Cap Install
-=deathtrap-mx3=-
Cap Install
My friend and I are gonna install (2) 1 Farad Caps in another guys car tomorrow. The only problem is, I dunno how to setup a cap. I thought i knew how, but I just read that they have to be grounded. If someone could make a labelled diagram for me. i'm confused:<BR>does the incoming power wire(from batt) connect on the same stud as the outgoing power? what's the deal with grounds? do you ground a cap?<P>----------0 0----------<BR>incoming? outgoing?<P>------------0 0-------------<BR>in and out? ground?
Looking for a 94+GS for KL-ZE fun
02 Protege DX Retired
93 MX-3 RS Gone But Not Forgotten
Re: Cap Install
wow is it just me or was this exact same thing posted on Sounddomain.com? U must be the same person.
GMGQ
Re: Cap Install
"Grounding" something is simply attaching a wire from the (-) negative terminal to any bolt attached to the body of the car.
-=deathtrap-mx3=-
Re: Cap Install
yes, i'm mx3bass on sd. i know what a ground is, i just thought that caps weren't grounded so i was confused. i've got the whoel run-down now though. i love my friends...
