Radio Problems
Radio Problems
a few days ago i got a muffler installed and when they did it the blew my "room" fuse so my radio didn't work but it would turn on but no sound a day later it just wouldn't turn on so i replaced the fuse and the lights work but the radio dosn't even turn on<P>i checked all the fuses and there ok<P>this happen to any1 before?<BR>Know whats wrong?><BR>i would bring it to the dealer but i work everyday and got no cash gotta save for system and alarm<BR>thanks
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Bri94GS
Re: Radio Problems
Did you check all the fuses in both fuse boxes?? There's one in the car near the trunk latch, and there's one under the hood as well. Also, if you have an aftermarket stereo system with an amp, check the fuse for the power wire to the amp. Other than that, make sure all your connections to the radio are connected....does it not turn on at all? Or does the radio not work? Does the clock come on??? try pushing and holding the volume button on the head unit...sometimes that makes it power on<P>P.S. if you blew the radio, i got a stock 626 radio for sale (cheap) that will plug into the MX-3 harness...let me know...pz<P>------------------<BR>~'94 GS (Creek Blue Mica)<p>[This message has been edited by Bri94GS (edited August 26, 2001).]
Re: Radio Problems
ya checked all the fuses and the radio dosn't turn on at all<BR>and my clock gets reset everytime i turn off the car<P>i even switched the fuses to see if it was the fuse but it didn't make a diff<BR>thanks for the help man<p>[This message has been edited by Marlon (edited August 26, 2001).]
2004 RX-8 - Project
2004 RX-8 - Project
Bri94GS
Re: Radio Problems
If you're clock gets reset, that means that it isn't getting powered....it's basically like you're battery is getting unplugged everytime you turn the car off....check all your connections to the battery....do you have a car alarm or strobe lights or something else attached to the battery? If so, check the wiring to those things, because that can cause a mess as well<P>------------------<BR>~'94 GS (Creek Blue Mica)
