Bad leak
Bad leak
Every time it rains my car has a puddle of water on the floor in front of my seats. It looks like its comming out of the top of the door somewhere. I think it has something to do with my sunroof. I looked at the sunroof and saw that about a inch of the rubber gasket was not there around the sunroof. Is this the problem, and has anybody had this problem? Where can I get that gasket at? Thanks
Re: Bad leak
Just pointing out the obvious, not trying to be rude...if you said an inch of rubber is missing from the seal in your sunroof...kinda sounds like that might be your problem...
My Cardomain site
My Cardomain site
Re: Bad leak
that only answers one part of my question. Am I going to have to go to a dealer for this part? Thanks for the reply though.
Re: Bad leak
no clue man... i'm tryin to get replies to my question with no luck so far! (do u know where i can get a used gearbox for manual GS?)
"Bart, you will be promoted to 'man of the house', Lisa, you will be promoted to 'boy'"...Homer simpson<BR>-----------------------------------<BR>1992 MX-3 GS, 5 spd.
Re: Bad leak
No I don't sorry
Re: Bad leak
is the missing rubber in the middle of the front?
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: Bad leak
Yea
Re: Bad leak
How did you know it was in the middle front?
Re: Bad leak
Cause everybody's sunroof rubber does this. It's called shrinkage.
Re: Bad leak
I have NOOOO shrinkage
. My sunroof just wont even open now.... DOH
Shaun Newman
Re: Bad leak
So do I just need to get a whole new gasket? And where can I get one?
Re: Bad leak
Before you spend anything try verifying were the leak is. Have a friend spray water with a hose at or on the suspect areas. You should be able to locate your leak this way.
The reason I mention this is it could also be the front windshield seal. It took the dealer three times to finally seal my windshield up. The third time they called in outside help.
Good luck
Andy P. 93 GS
Good luck
Andy P. 93 GS
Re: Bad leak
i got the same problem with the water, but i dont even have a sunroof..<p>i had the weather seals replaced on my doors, and now my passenger side door won't even close all the way...<p>fahqing dealerships really dont know what theyre doing here
Sold my 95 RS "Little Peanut" but she will never be forgotten.
Re: Bad leak
what i would do in the mean time go to home depot and buy weather stripping for doors cuz im sure the parts xpensive,that way no water hopefully till you get it fixed
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
Re: Bad leak
If I take it to a dealer and they look at it, would they charge me?
