Turbo in a can....
Turbo in a can....
check this out...<P><A HREF="http://www.geocities.com/airfastme/turboinacan.html" TARGET=_blank>Turbo in a can</A>
Re: Turbo in a can....
that just sounds like a bad idea to me, you figure you could let out a few psi at a time which wouldnt really do anything, or 125 psi in a few seconds, too much air! ahh well
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Ahem....Here's a link to the same guy's "Turbo 3000" product:<BR> <A HREF="http://www.geocities.com/airfastme/i.html" TARGET=_blank>http://www.geocities.com/airfastme/i.html</A> <P>Nuff said...
lol... that second link is a bilge pump for a boat. there was this hole warning thing on eBay awile back. would that be fun when those blades snap into your intake? yay.
92 Mazda MX-3 GS: blaze red, bone stock, and daily driver
86 RX-7 GXL: '94 LT1 V8, 6 speed tranny, scary fast. SOLD
93 Mazda RX7 R1 LS1/6speed... 75% complete
http://www.cardomain.com/id/mattsterrx7" onclick="window.open(this.href);return false;
^link to my V8 swap page
Well, it's not a bilge pump, but it is for a boat. I believe they are primarily used as heat exhaust fans.<P>And in case there's any confusion, I didn't post it as a recommendation, I posted it as a warning.
This sounds kinda like how a real Turbo or supercharger works, however will this really make a difference? Sounds to me like it might but only for a few seconds kinda like NOS? What do you guys think?
- Shades
I think "Turbo in a Can" is just a very expensive way to dry your hair... makes a very good hair dryer... 125psi will not only dry your hair but also rip it out of head!
"Do it ONCE, do it RIGHT!"
- Custommx3
- Site Administrator
the damn Turbo in a can is a freakin Air tank from walmart painted black. what they dont show you or tell u that its 125 psi, but 1 shot of it, steadily degrading as you use it. <P>The other is a PIS, its a boat fan used to blow out exhaust gases. A co-worker bought the exact one for his boat, he said the fan is glued to the shaft and kept falling off.<BR>you guys see the guy on ebay?<P><A HREF="http://cgi.ebay.com/ebaymotors/ws/eBayI ... 1858667899" TARGET=_blank>http://cgi.ebay.com/ebaymotors/ws/eBayI ... 8667899</A>
- Andrew_Pakula
I wouldn't trust something like that, it looks like it could be in one of those infomercials you see on TV at 2am.<P>I'd be afraid it would blow up my car or something.
125psi at 1cfm is pretty muchly worthless. And how are you going to control how much you "boost". Or how much additional fuel you'll need. <P>Dumb Idea #3298
David Coleman
No no, those boat fans are great, if you like hearing a really loud "thwack" under your hood when you rev the engine and a blade snaps. been there seen that
And yeah, it was in some kids civic, go figure...
Build A Man A Fire, He Will Be Warm For A Night. Set A Man On Fire, He Will Be Warm For The Rest Of His Life.
<img src="http://www.bareend.com/mazdaspeed.gif" alt=" - " />
- mmonid
The ad says that it comes with a regulator. How long do you think it will take to empty that tank, at say 8psi? The air coming out will also be fairly cool, acting like the air has been through an intercooler. I am not sure if this is correct, but it seems reasonable. I don't think I would ever get it, but it got me thinking.<p>[ September 17, 2002: Message edited by: reklez ]
Matthew Monid
1993 MX-3 RS 5-Speed (Sold)/1997 Volvo 850 AWD Turbo 5-Speed
As reklez said.. It comes with a regulator. This means it should just let out a slow stream of air... Now if this is injected into the intake manifold at a constant say 8 psi. This would then act as if it was a turbo.. Now it might only last for a few minutes of this but even so it should work in theory right???
That tank is crazy! To get the kind of flow youd need at any pressure would suck that puppy dry in a microsecond. That tank device is pure and utter conman material.
