Getting quite a bit of work done today...
Well the ol Neon went into the shop yesterday to fix a notorious problem. I first noticed that I had an exhaust leak about 3 months ago, and I finally got enough money to go get it fixed. Thats not the problem though. Turns out it wasnt an exhaust leak after all, it was a compression leak from a cracked head gasket. So, I probably run a 15.5 with bad compression, I wonder what I'll run with full compression? Anywho, So she's in the shop till 5 today, getting a lot of things done. <BR>1. Head gasket replacement, shaved heads, reseated valves.<BR>2. Complete engine/coolant flush, decarboning<BR>3. New belts<BR>4. Exhaust manifold gasket replaced<BR>5. AC compressor wiring harness replaced.<P>I figure it will be really quiet and run 10x better after today. Oh and I need to change the plugs and wires but ill do that tomorrow.
98 Neon R/T - Iceman/K&N, Clear corners, Painted calipers, ceramic brakes, PIAA lights. New head gasket
Re: Getting quite a bit of work done today...
Well the new manifold gasket comes in next week and the new plugs and wires should be here tomorrow. Whew I wish we had an open track around here to see what she'll do. It already feels like its got an extra 20 hp on tap.
