sohc clutch kit on DOHC??
Joey's mx
Post by Joey's mx »
Hey will a SOHC clutch kit work on the DOHC because seems to me that ACT makes a better kit for the SOHC then the DOHC!!! Will putting the SOHC kit on the DOHC be a good idea??
LongJohn
Re: sohc clutch kit on DOHC??
Post by LongJohn »
The clutch and flywheel match the tranny. If you have a BP with the "F" series tranny, you will be able to use the SOHC clutch.
Joey's mx
Post by Joey's mx »
ok so would a DOHC clutch kit fit on the SOHC flywheel??
Joey's mx
Post by Joey's mx »
Will a SOHC clutch kit line up with the DOHC tranny??
LongJohn
Post by LongJohn »
The standard tranny from the SOHC is an "F" series tranny. The standard tranny from the another car hosting the BP engine is a "G" seriec tranny.
The standard tranny from the 94-95 MX-3 (DOHC B6) is a ??? (I don't know).
If you have a "F" series tranny, you must use the "F" series flywheel, and an "F" series clutch.
If you have a "G" series tranny, you must use the "G" series flywheel, and a "G" series clutch.
You cannot use a "G" series clutch on a "F" series tranny and vice versa.
Be careful calling something a DOHC tranny because I don't think the BP tranny (G) is the same as the DOHC tranny from a 94-95 MX-3. Someone who knows should elaborate on this. It is better to call them "F" series and "G" series.
Joey's mx
Post by Joey's mx »
Ok i am just saying its a DOHC tranny because it came off my DOHC 1.6L!!!!
schwankesmx3
Post by schwankesmx3 »
yes it will work cause from 94-96 is still the f tranny if its a 1.6 ..... sooo yes the sohc 1.6 clutch will work on the 1.6dohc...............if this helps any
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
