Reverse lights stuck on.
Coady
Post by Coady »
When probs hit, they seem to come one after another. My reverse lights remain on. I think that the switch on the shifter(Manual) may be stuck. Any suggestions or other ideas?
mykel78
Re: Reverse lights stuck on.
Post by mykel78 »
Check out the switch. I had an odd thing happen to mine. I installed a new clutch, among other things, and when I got it back together, the oddest change had happened. No reverse, I had only forward gears, and the reverse lights came on in fifth gear. This was caused by misplacing the seal/washer on the switch. There could be some damage to the switch or wiring that is shorting it.
If not broke - don't fix, modify. If broke - fix it right, and make it better.
Ateana
Post by Ateana »
look in your engine bay on the right hand side on the transmition theres a round plug with 2 wires coming out follow those wires to the connecter and check that its all intact. mine rusted and shorted out thats the reverse sensor.
Management is not responsible for lost or stolen virginities.
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
Ateana
Post by Ateana »
oh and post back when you figure it out. im curious if you had the same problem
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
