New to COLD climates
Coady
Post by Coady »
I recently moved to Northern AB Canada. And right now we are hitting -30. Both my car and myself are new to these temperatures. I had a look but i could not find a block heater. Do anyone know if the 1995 4cyl came standard with a block heater? I am also having a bit of a problem locating the Thermostat. I can talk the talk but i can't walk the walk, so I want to start doing the little things myself. Any suggestions?
Darcy
Re: New to COLD climates
Post by Darcy »
Check the online shop manual on this site for directions on replacing/adding parts to the car.
I do believe I have an extra block heater lying around here somewhere, but i think Canadian Tire also sells them.
The thermostat is right by the distributor
Coady
Post by Coady »
Thanx Darcy, Best of Luck with that dump of snow you are suppose to be getting down that way.
