oil pressure guage
jonny_boo
oil pressure guage
anyone know where to wire the oil pressure guage to?
Re: oil pressure guage
You need to put in a sender unit and wire from there to the gauge. The best way is to make up a tee piece where the oil pressure light goes and install the sender unit and oil pressure light there. Otherwise you can remove the oil pressure light altogether and screw the sender straight in. This means you won't have a light though and will need to rely only on the gauge.
The only other wiring you might need depends on the gauge you're putting in, you probably need at least a ground and dash light supply that can be picked up under the inside fuse box.
