bp? bpt? stock?
bp? bpt? stock?
was just wonder what the difference between these engines are, and how much horsepower each produces.
thanks
thanks
- Franko
Re: bp? bpt? stock?
I am pretty sure that it is like this.. Correct me if I am wrong anybody
bp dohc 130hp
bpt dohc gtx 180hp
bpt gtr dohc 220hp
stock sohc 92-93 88hp
stock dohc 94+ 110hp
<small>[ October 09, 2004, 10:09 PM: Message edited by: Franko ]</small>
bp dohc 130hp
bpt dohc gtx 180hp
bpt gtr dohc 220hp
Re: bp? bpt? stock?
bp dohc 122-127hp(excluding miatas_Originally posted by Franko:
bp dohc 130hp
bpt dohc gtx 180hp
bpt gtr dohc 220hp
bpt dohc gtx 180hp (rounded. its really like 177)
bpt gtr dohc 220hp (cloes enough i forgot the actual numer)
stock dohc 94+ 105hp (the miata verions is 116 though)
<small>[ October 10, 2004, 12:07 AM: Message edited by: torpedan ]</small>
-torp.
I don't own a Mazda.
Re: bp? bpt? stock?
only 88 hp for sohc stock...ouch,. im offically saving for an engine haha.
Re: bp? bpt? stock?
also, i was wonder what the prices for a bp and bpt and bpt gtr would be, and where i could possibly pick one of these babys up, perferably in canada.
and if its all compatible with a 93 1.6 4cyl RS
<small>[ October 10, 2004, 02:05 PM: Message edited by: xian55x ]</small>
Re: bp? bpt? stock?
GTRS are usually impossible to find.Originally posted by xian55x:
You can get a BPT from www.corksport.com there are quite a few other vendors out there tough.. Most of which are cheaper. a BP would have to come from a junkyard. You might be able to find a importer for them
-torp.
Re: bp? bpt? stock?
alright, ive narrowed it down to eaither one of these two options:
1.8L T4cyl (BPturbo) w/approx 180 HP, It says on the site it is difficult to install, so im still on the fence for this one. is this actually true or are they jsut saying it?
the other option was the 2.0 V6 (KF-ZE) w/approx 165 hp, not as much HP as the first one, a little cheaper tho, also corksport mentions something about changing the wiring/ECU, mounts tranny, is this neccessary, if so how much will this cost?
- MX3-Freak
Re: bp? bpt? stock?
Think you have the difficultly backwards. The RS and GS mx-3's are completely different under the hood. I assume you have the RS because you are in the 4cyl forums. Thus, the BP-ZET will be easier tehn any 6cyl.Originally posted by xian55x:
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
Re: bp? bpt? stock?
if i decide to use the BPT, am i going to have to replace a ton of things in the car? or is it gunna be completly fine without? minus new brakes etc.
Re: bp? bpt? stock?
the difficulty of the bpt swap depends on what year mx you have.. if it is 92/93 with the sohc its pretty easy.. if you have 94 or newer with the dohc its pretty difficult.. and probably better to simply build up the stock dohc
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
Re: bp? bpt? stock?
i have 93 model with the stock sohc. im jsut wondering what all the parts that need to be changed would be so i can get a ball park estimate of the cost etc, you know what i mean?
your info has been very helpful so far and i appreciate it a lot.
Re: bp? bpt? stock?
don't just pick the BPT because it says 180hp vs. 130hp. The BP is essentially the same as the BPT minus it doesn't come with a turbo that's too small. Do a search in regular internet search engine for mazda interchangability guide and it will tell you differences of Mazdas B series motors in there. The BP are a dime a dozen to pick up and would reliably handle at least doulbe stock horsepower. It really is a very over built motor for it's task. With the money you save on the BP from BPT, you can buy a proper turbo kit and fuel components for your BP and live happily ever after.
quick short list of regurgitated info that you can find while searching this site. may be missing info from list. Basically, the swap should be very easy any way you do it with the sohc.
Easiest way-
You can put in the BP motor using stock transmission (2 wires differ for VICS from BP harness to our 1.6 sohc harness...). Use BP ecu.
Keep your crappy brakes, weaker transmission... and live happily like that until you can afford more.
Or swap in the rest...
The BP G series transmission is apparently better/stronger.. if you use that, it requires swapping more. engine mounts, cv shafts (possibly hub assembly? don't know if diameter or splines of shafts at hub are different or not).
With that extra power, you can use brakes from Pro LX or Escort GT. etc.
Cheapest way to do it all... pick up a donor vehicle. More expensive way... do a little bit at a time.
Easiest way-
Re: bp? bpt? stock?
oh wow, thanks alot "what", your info has helped alot, and ya, after reading what you said about the bp vs. bpt it has made me condsider my options more, so im thinking im gunna pick up a BP from somewhere.
Re: bp? bpt? stock?
after more research, i found that alot of the sites dealing with these engines uses a lot of different abreviations of "BP", some have numbers, some with a few different letters etc, i havent found one that just says "BP", maybe im not looking for the right thing, or i jsut dont know which one to be looking at, help me please :p
