No spark 93 4 cyl HELP
Help, gotta 93 4 cyl 194K miles....been a great car. Went to start today and just kept cranking....no fire at coil, no movement in tach while trying to start and no "engine" light while cranking. Tried a new, well used, distributor no luck....Any ideas?
Re: No spark 93 4 cyl HELP
I hope you get it figured out - I have tried everything with my car and no go.
Definitely check your fuses first. Could be your ecu. One guy recommended checking the Crank Angle Sensor.
