fuel injectors
Posted: August 6th, 2004, 6:07 pm
by schwankesmx3
i hav been hearin on this site that people are putting eclipse injectors on the b6ze turbo projects well i had a crazy idea if the injectors are them same then would a fuel rail from the eclipse work? or hell how bout aftermarket injectors and a biger fuel rail will it work?? i dont know just throwing out the idea has anyone tried if not im going to try
Re: fuel injectors
Posted: August 6th, 2004, 6:27 pm
by papa roached
the fuel injecots fit where ours go but the fuel rail probably wouldnt work because the spacing between injectors would be different i would think
Re: fuel injectors
Posted: August 6th, 2004, 9:09 pm
by jaydog5678
Nobody makes a bolt in fuel rail for our car. You dont even need a rail unless your attempting to make over 600hp give or take a few ponies.
The Eclipse injectors will fit, however they don't fit the stock wiring connector that plugs into them.
<small>[ August 06, 2004, 08:10 PM: Message edited by: jaydog5678 ]</small>
