fuel injectors
schwankesmx3
fuel injectors
Post by schwankesmx3 »
i hav been hearin on this site that people are putting eclipse injectors on the b6ze turbo projects well i had a crazy idea if the injectors are them same then would a fuel rail from the eclipse work? or hell how bout aftermarket injectors and a biger fuel rail will it work?? i dont know just throwing out the idea has anyone tried if not im going to try
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
papa roached
Re: fuel injectors
Post by papa roached »
the fuel injecots fit where ours go but the fuel rail probably wouldnt work because the spacing between injectors would be different i would think
jaydog5678
Re: fuel injectors
Post by jaydog5678 »
Nobody makes a bolt in fuel rail for our car. You dont even need a rail unless your attempting to make over 600hp give or take a few ponies.
The Eclipse injectors will fit, however they don't fit the stock wiring connector that plugs into them.
<small>[ August 06, 2004, 08:10 PM: Message edited by: jaydog5678 ]</small>
