can u have headers if you have turbo?
my friend said u cant have headers if u get turbo...u see i was gonna put in some probe headers on my 95 dohc...but my friend said not to if im planning to get turbo, which i am...so if i get some headers and a nice exhaust made, will it be easy and ok to put in turbo? thanks
www.illegalCustoms.com
Tri-State Area Car Club
- babyblueMX3
Re: can u have headers if you have turbo?
if you are going turbo then you'll need a turbo manifold meaning your headers won't match...you'll have to mod them if you want them to fit..but I would suggest not to get them
RIP 400whp ZE-T MX-3
- mitmaks
headers will sure benefit since youll be flowing lots of cfm air you need good exhaust
- babyblueMX3
He shouldn't buy after market ones but get a custom one made since he's turboed (well will be)..too much modification would have to be done to it
does anyone else have probe headers with and turbo?
i want to get headers and then from them back will be a custom exhaust...arnt headers better than that ugly cat converter and a rusty shield?
You realize somewhere along your exhaust you will have to put the turbo in right? If you put in the probe header, a turbo will not bolt up directly to it and a flange would have to be made. Why not save your money and just wait and get a turbo header/manifold? I think you should do some research on turbo's before you decide to put one in, as the answer to your question would be pretty straight forward if you knew how a turbo system worked. And another thing, Im pretty sure the probe header is designed for an NA application, you might not get any performance gain from it with a turbo... but i guess it will look nicer
http://auto.howstuffworks.com/turbo.htm
Great Book - Maximum Boost by Corky Bell
if you're concerned with looks, have your manifold ceramic coated when you get your turbo setup.
<small>[ July 29, 2004, 07:58 PM: Message edited by: OsoSlo z28 ]</small>
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
i don't think you understand the concept of turbo VS naturally aspirated. the turbo runs off of hte exhaust manifold. Another name for an exhaust manifold is a header. Most ppl think of a header as having tubular piping coming out of a flange but headers can be cast as well.
You can have a tubular, equal legnth turbo manifold made if you want looks, or you can just use the cast peice from the B6T that looks crappier and more OEM.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
