Platnium VS. Platnium 4s ????????
MOSES
Post by MOSES »
is there any diff in the spark plugs with the one head and the four heads???
<small>[ July 19, 2004, 12:48 PM: Message edited by: MOSES ]</small>
I've been so unsatisfied with my car since I joined mx3.com.
Seeing all the body kits, rims and engine swaps makes me want to spend all my student loans on my car.
Ehpl
Re: Platnium VS. Platnium 4s ????????
Post by Ehpl »
The guys I have talked to say they see a increase in idle smothness but in a day or so all the gains seem to go away. The plug that seems to work the best in mx's is the recomended standard NGK plug. platnum an ridium plugs just last longer.I like to change plugs every year so it doesnt make sence to use them.
Eugene L
1.6DOHC
N.S.canada
http://www.cardomain.com/memberpage/552384
MOSES
Post by MOSES »
thanks alot man, every talks about these plugs and "low resistance" wires, i wasnt sure if i would invest in these,but you helped me make up my mind
Rope04
Post by Rope04 »
i use Iridium Plugs from Ngk...they have a more positive power point to one area which gives it a more powerful spark..They worked for me and I saw a difference...I have been through several sets of ngk platinums and four prong but the Iridiums outlasted and out performed the rest...So I reccomend the Iridiums...Thats whats in my K8
P.S they cost Like 8 Bucks a plug though...at least where i live
Ferrari Red w/silver Metallic 92' Mx-3 GsR: Blown 5 Built motors from my past project and am going to N/A for a while as I get use to Megasquirt for proper tuning then may boost....TT setups have too much lag and too low of a power output for the rpm range i sought....Single is better and may do that in future...New project is custom Alum Mani/ with 3-4" runners...NO ?'s about my previous setup I don't want anyone to waste as Much $$$$$$ as I did...listen to BabyBlue and the those guys and go with thier F/I setups
Sonicxtacy02
Post by Sonicxtacy02 »
Platinums/iridiums give you no additional gains, just last longer
Shaun Newman
Rope04
Post by Rope04 »
ok...Lets take something thats easy for you to understand....Like Tig Welding....You use a tip thats Filed to sharp point,of course you have acheived a more finese weld, you have more positive energy flowing through the tip of the Rod which enables the Gas to ignite much better...UNDERSTAND
Rope04
Post by Rope04 »
as for the iridiums the tip is very fine which energy is allowed to concentrate more in a specific area rather than spread out....But knowledge is power and thats my opinion so srry if I were a lil to harsh...by no means do I like being a ****...Mx-3.com has come a long way and Is by far the best site on the net
MX3-Freak
Post by MX3-Freak »
This is all im going to say....striaght from NGK.
<img src="http://www.ngksparkplugs.com/images/Iri ... rLines.jpg" alt=" - " />
Stock 1995 RS - Creek Blue
Car Meanins:
papa roached
Post by papa roached »
use a single tip plug, everyone and i mean EVERYONE i know that has used these multi point plug setups say they run like arse
SLUmx3
Post by SLUmx3 »
I work for an auto parts store and have for some time. We work closely with the Mazda dealership and they recommend NGK. They are now using them almost exclusively off the lot. The Bosch platinum 4's wont give you any extra gains. The Bosch 4's are mainly for german cars. Hope the info helped everyone.
