differences in trannys
Redlined
Post by Redlined »
im searching and im confused as hell
is there a dif in the tranny from the 92-93 mx3 rs and the 94-up rs?
Redlined
Re: differences in trannys
Post by Redlined »
someone? they are different right?
Marlon
Post by Marlon »
i don't think so
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
Limegreen mx-3
Post by Limegreen mx-3 »
trany on dohc and sohc look the same but they seem to look different where they connect to the engine. i have both thats all i can say sorry if its doesn't help but i do belive trany on shoc or dohc are interchangeable.
Yoda
Post by Yoda »
Yes they are the same, also the same tranny as the 90+ 323, SOHC Protege, Kia Sephia and all 95+ Protege including 2.0 up to 2001. In late '96 the tranny was beefed up a little to handle the torque of the bigger engines which all benefited the MX-3. The 1.5L AZ-3 and Presso came with the "G" Tranny because of the high output of this engine.
jimishadow
Post by jimishadow »
good info yoda.......
Post by Josh »
Nope they are not the all the same. there is an F series which you find in our cars and the kia, ect. then there is the G series which you will find in like a PRO LX. which are stronger and have different gear ratios.
