lost a cylinder
lost a cylinder
im only runnin on 3 cylinders was this way when i got it been this way for round 3 years runs rough at idle fine other wise i plan on fixing it but not sure where to start with this one anyone help on how much it might run me 2 fix
- Custommx3
- Site Administrator
Re: lost a cylinder
First....
see if your getting any fire on that cylinder.
Go ahead and change plugs/wires/cap/rotor.
Could be distributor related, but try the above replacements 1st.
Re: lost a cylinder
change ur spark plugs <ngk V-power $7> plug wires doesnt matter but about 35-55...distributor cap 55-100 and ur timing belt 25-50 then put some fuel injector cleaner through it with 93oct. if that doesnt clear it up then take it to a shop
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
Re: lost a cylinder
regular ngk's will work fine. a timing belt is not needed if you're timing is fine. disty cap is about $20 and the rotor is about $12 from autozone. please do not spread wrong information.
<small>[ July 06, 2004, 09:26 PM: Message edited by: OsoSlo z28 ]</small>
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: lost a cylinder
I got my cap and rotor for $55.00 US from my local mazda dealer. They are much cheaper here Genuine mazda parts
Black 94 RS, Erebuni MS style front, OEM sideskirts, Clear signals, altezza tails, 93 seats, Civic projectors
Re: lost a cylinder
wouldnt the car not run if all cylinders werent working? thats what i thought...could be wrong
www.illegalCustoms.com
Tri-State Area Car Club
- MX3-Freak
Re: lost a cylinder
Most engines will run with one, maybe two missing cylinders. But power is lost and so is smoothness.
A few companies owned by GM actually use a v-8 that run on 8 during heavy accelerations/loads, 6 normal accelerations, and 2 when cruising at a constant speed. They can do this because an engine is only using about 20% of its potenial power at highway speeds.![Shrug :shrug:](./images/smilies/shrug.gif)
<small>[ July 08, 2004, 06:26 PM: Message edited by: MX3-Freak ]</small>
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
Re: lost a cylinder
thx for all the suggestion this forum really does rule im goin to try replacein the plugs first and go from there thx again
- Yoda
Re: lost a cylinder
If your engine is a SOHC, chances are that you lost compression on the 1st cylinder. This seems to be common to the 16 valve B6 SOHC. All the SOHC MX-3s I've seen have 25-30% less compression on this cylinder and run normally but with loss of power. This loss of power has probably gone unnoticed since it would have been a gradual over a long period of time. When they loose 50% or more is when they start or feel rough. This loss of compression seems to be related to valves or valveseats damage.
- atlantamx3
Re: lost a cylinder
hmmm... had the same thought after reading Yoda's posts.Originally posted by atlantamx3:
Is that VAUGHN??
![Confused2 :confused2:](./images/smilies/confused2.gif)
