INTAKE QUESTION
Posted: April 11th, 2004, 2:33 pm
by Joey's mx
I have a 1.6 DOHC with a k&n cone filter and when i shut my car off it doesnt make the air noise like a Honda, is it not suppose too??
Re: INTAKE QUESTION
Posted: April 11th, 2004, 3:20 pm
by MX3-Freak
I don't really know what you're talking about... And if it is a noise your not hearing your worried about, I think you have your priorities backwards...Anyways, I don't have an "air noise" when I shut my engine off. I really wouldnt worry about the absense of a noise...its when noises start getting made that you should start worrying.
Re: INTAKE QUESTION
Posted: April 11th, 2004, 4:10 pm
by Guard-TL-
I think he means the sucking in air noise. After you turn off your engine air is still sucked in for about a second or two. Why you can't hear that noise i don't know. :dunno:
<small>[ April 11, 2004, 03:10 PM: Message edited by: Guard-TL- ]</small>
Re: INTAKE QUESTION
Posted: April 11th, 2004, 4:11 pm
by papa roached
this has me lost
Re: INTAKE QUESTION
Posted: April 11th, 2004, 4:41 pm
by Joey's mx
the air that comes out of the filter when you shut your car off!!
Re: INTAKE QUESTION
Posted: April 11th, 2004, 5:57 pm
by torpedan
Sorry bud.. but its not a honda.. why should it act like one?
This could also explain the various huhs and wha's? and wtf's you will get for responses. No worries
Re: INTAKE QUESTION
Posted: April 11th, 2004, 8:07 pm
by Joey's mx
Cool man thanks i just wanted to make sure everything was set right
Re: INTAKE QUESTION
Posted: April 12th, 2004, 12:01 am
by sweetmx3
my bro mx6 makes that sound when he shuts the car off it sounds likes that like sssss and when he shifts u can here it breathe inward :shrug:
Re: INTAKE QUESTION
Posted: April 13th, 2004, 1:29 am
by Josh
its because of the stock rubber intake piping. if you change it to a nice none restrictive aluminum piping then you will get the noise you are looking for. its because of the ribbs in the oem intake pipe, they restrict the air flow.
Re: INTAKE QUESTION
Posted: April 13th, 2004, 6:57 pm
by mnuckols
are there any intakes to buy for the 4cyl sohc to replace that plastic piping coming off of the tb into the maf and then the 2nd piece with filter to go down into well?
Re: INTAKE QUESTION
Posted: April 13th, 2004, 7:14 pm
by stock3
Your intake tubes have to be custom. NO one makes for the MX3 DOHC, if you run off of the SOHC you can try anywhere, found cheap ones on ebay.
Re: INTAKE QUESTION
Posted: April 13th, 2004, 9:40 pm
by Joey's mx
Civic cold air system works might just have to cut it alittle
Re: INTAKE QUESTION
Posted: April 13th, 2004, 9:49 pm
by Josh
there is a cold air intake system for the SOHC on ebay for like 60 bucks. and for the DHOC i used a one piece cold air for the acura integra
