1.6L aftermarket
1.6L aftermarket
Are there any internals available for the 1.6L such as pistons / cams / cam gears / pistons / rods? I know there are no headers specifically for it and there is a list of t.b.'s you can swap over with a tiny bit of work. Would any of the internals from a 1.6L miata work?
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
Re: 1.6L aftermarket
yeah Miata Internals for the 1.6 should work fine as the differences in these motors are very minute
- monty73741
the cams work but u need to switch em so the miata intake wil go on the exhaust side of the mx-3...& the exhaust side of the miata will go on the intake size of the mx-3
Jason Danaher
Please Help Support MX-3.com
- atlantamx3
I think thats only for the DOHC model. The SOHC was never offered in a Miata and will not work with Miata cams.
well that is good cause the model i'm askin about is the DOHC...
hoping to be buying one very soon.. depends on how it goes.. will know later tonight
ProjectMx
Cardomain
Cardomain
whats the difference in compression ratios between the 1.6 miata and the dohc?
- Josh
none they are both 9:1.
Soooo...Can I use the Miata B6-ZE inner shim kit, gaskets and racing belt from Toda Racing??
Cris
![Image](http://img404.imageshack.us/img404/6351/zz1tb.jpg)
- Josh
yes; BUT the gasket. you have to find out if the gasket will fit. i had a problem with the head gasket on my turbo engine. some of the miata blocks dont have the two oil jurnals on the exaust side of the block, and our BF block does. you have to make sure that the gasket has two flaps that stick out on the exaust side, or you will have oil all over the place when you start it up.
Thanks a lot Josh!!
Just what I need to know!!
Are you using some custom gasket??
![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
Cris
