idling problem on 1.6dohc
Posted: February 27th, 2004, 12:13 pm
by tommygunzit
my 96 4cyl w/ auto is acting up every so often. It only happens sometimes. When i come up to stop at a red light and stop, sometimes the engine almost wants to stall out. It goes to normal idle and dips down for a second then goes back up again. It will happen one light and then not the next. If i put it in neutral or park it won't do it at all. Does anybody know if this is bad plugs, air restriction, fuel filter or someother symptom of something bad coming? any info would be greatly appreciated. thanks
Re: idling problem on 1.6dohc
Posted: February 27th, 2004, 12:36 pm
by guyaverage
Posted: February 28th, 2004, 3:28 am
by Som1Dies2Nite
Any codes stored in your ECU?
