1/4 mile times for 4cycl turbo MX3
osargeant
Post by osargeant »
Could you guys who have turbocharged your existing MX3 motor or swapped in either the B6T or the BPT engines post your 1/4mile times.
I am keen to see what 1/4mile times the turbo 4cycl Mazda MX3s are doing. I have yet to run any 1/4mile time with my turbo MX3 and would like some figures to strive for.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
torpedan
Re: 1/4 mile times for 4cycl turbo MX3
Post by torpedan »
http://www.mx-3.com/ubb/ultimatebb.php?ubb=get_topic;f=22;t=000222
you can find them in there sorry it needs a update just didnt touch it for the off season =]
-torp.
I don't own a Mazda.
Shady469
Post by Shady469 »
wait a little while into the season. i'm predicting the turbo 4's are going to dominate the board... we've all pretty much done rebuilds and are coming out with a lot more power and mods(and alot less weight in several cases).
i just hope we can get some recognition at events... it's kind of hard to be competative in the turbo 4 classes when your racing B-series hybrid honda's with turbos and/or N20. i quess we'll have to see...
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
philcosta
Post by philcosta »
i will post my results during the season
94mx3rsr
Post by 94mx3rsr »
I am #13 ...ran the car twice with a clutch slipping badly, a total of 3 runs
result
gave 14.85 @ 96mph with 60ft of 2.35 which is not good. running 8.5lbs of boost on a warm night with a stock exhaust (stock boost)..on a bp55 mapping
13 seconds is no problem with 12 lbs and updwards of boost and a 2.5 inch exhaust....
expect around 13.6-13.8 and 102-105mph trap speed with a bpt gtx with stock turbo, 2.5 inch exhaust and k&N filter and 12-15 lbs of boost.
Jean-Michel Basque
STOCK BPT @ 8.5PSI
3 RUNS ON THE 1/4 = 14.85 @ 96
