Engine Swap Question
hey guys what up? i have a 4 cyl. auto. how much would it cost to swap in a KL-ZE and convert it to a manual. also, how much would it be if i did this with the BPT instead? thanks.
Re: Engine Swap Question
you have a 4 cyl you shouldnt go with the ze its expensive and hard to install
got with the bpt since its bolt on
it cost me 3800$CA for the motor and installation
GTX ecu 220$US
GTX ecu 220$US
http://www.cardomain.com/id/phil_costa
<img src="http://smkclan.com/images/snake/articbeast.jpg" alt=" - " />
There are shops that will swap a klze (a-spec.ca), but it is really expensive.
A guy here in London put one in and apparently he springs oil leaks constantly.
No Sig
If you want to swap engine and tranny, go with a BP-T Conversion, it would cost less than a ZE Conversion. now if you had a 5 speed tranny, Go B6-T.
1994 Mazda MX-3 RS (Project RS-T)
aight guess im goin with the bpt. thanks guys.
