tell me how 2 change my tranny please
can some on tell me how to change my tranny please i need alot of help here!!!
3-1-0 RACING club PREZ.
94' mx-3.....was all motor now awd bpt
91' 323....daily driver
78' cutless coupe...bad a-- mofo v8
95' eclipse gsx......awd turbo 11.4 eta
Re: tell me how 2 change my tranny please
you mean replace the tranny itself or the fluid??
DONATE TO MX-3.COM
DONATE TO MX-3.COM
the tranny itself
first, you jack up your car, take the right tire off, and take the rotor off, and disconect where the strut connects with the nuckle, to give room for your drive axle to come out. then you disconect the tranny mount under the battery. after that, you get under the car and unscrew the bolts around the tranny itself (works easier if you have a small jack under the tranny to hold steady when coming to last bolts). last slowly pull your tranny out from under your car. you might get a little fluid on the floor...
there ya go
Justin
there ya go
Justin
93' Mx-3 GS, repainted laguna blue with pearl, 18 inch wheels (white) with Falcon ZE512 ruppers, custom headers with 2 1/4 inch exhaust, ported TB and intake manifold, ACT clutch, and ground-control coil-overs.
well ive got all the cv axles off and the cables and wire's n stuff all off but when i put the new tranny in where do i fill it with tranny fluid?????
