TPS Output Voltage Lead wire
Gkreator
Post by Gkreator »
I'm trying to install my Zex kit, but I'm not sure where my Throttle Position Sensor Output Voltage Lead Wire is. I looked in my Chilton's with a friend and we are guessing it's the Blue Wire with the Black stripe that's on the top of the Throttle wire outputs.
Also where should I be looking under the dash to find a 12 volt accessory wire? Any help appreciated.
<small>[ December 13, 2003, 09:10 PM: Message edited by: Gkreator ]</small>
Dave Hyatt
94 Teal MX-3 RS 5 Speed
http://www.cardomain.com/id/gkreator_inside (New Pics!)
Spydie
Re: TPS Output Voltage Lead wire
Post by Spydie »
the tps should have 4 wires coming from it (if it's a V6 anyway)
tap the 2nd wire from the top.
not sure of the colours cuz I don't have my car anymore but that's the one.
<small>[ December 13, 2003, 11:31 PM: Message edited by: Darren Hyderman ]</small>
Gkreator
Post by Gkreator »
My friend Ashley was able to inform me it's the Blue with white stripe for the output voltage lead. I have the 4 cyl.
Now I just need to find a 12 volt wire under the dash.
Dave Hyatt
