I N T A K E H E L P !!!!!!!!!!
I have a 92 rs I want to know if and when u put a cold air intake in do u have to connect that hose that come out of an air box i think that is behind and below the driver's side headlight and paln on custom making one please info will help.
Re: I N T A K E H E L P !!!!!!!!!!
i put a cone style filter on ming and i just put some coffee filters over it and duct taped it in place, no prob, i dont know if you have to but i did just to be safe.
does antbody else know anything about this if so please respond I already posted this a while back but nobody responded thanks.
yes connect the hose. if it was connected before you'll want it connected again
- atlantamx3
Um-- NO you dont connect it to anything. You need to take that hose off, and the box it is connected to down in the fender well.
It is only a resonator and will not do any good with your new intake.
Just pull it out ( I cant rememeber if there are any clips or screws holding it in...)
Um you can't just say no disconect this disconnect that, why would it not work with the new system, what is that hose for, what does it afffect, it's not there for no reason.Originally posted by atlantamx3:
exactly.....
Theresa said "hose" not air resonator.
The resonator can be removed....but the vacuum hose must be reconnected.
Theresa do you mean hose or resonator????
- atlantamx3
On the 4 Cyl-- there is a air resonator that attaches to the intake box by way of this hose. The hose seems to disappear down behind the driver's side headlight, but attches to the resonator I am talking about.
If you replace your intake, and remove the airbox-- the hose has nothing to attach to. It is not a vacuum hose.
So-- if the hose you are speaking of was attached to the bottom/side of the OEM airbox and goes behind the drivers side headlight (Which I assume it does since you mentioned it in your 1st post) then it CANNOT attach to anything if you have removed your airbox & replaced it with a Aftermarket intake.
You can feel free to leave it there-- but do what everyone else does and remove it.
- atlantamx3
BTW-- Darren-- you have a V6, and so does MorbidelBob. So it may be differnt on your cars.
I happen to have a 1992 RS and have done what Theresa is talking about.
So BLAH!!
LOL-- j/k guys-- calm down.
So BLAH!!
oh yeah 4 cyl.....I missed that part
1, 2, 3, 4......4 cylindars bwah ha ha ha ha!
<small>[ December 12, 2003, 01:59 PM: Message edited by: Darren Hyderman ]</small>
- cjthor
That hose is for the egr vent solenoid. If you want u can hook it up to your new intake or put a small filter on it and let it hang...It is up to you. Problem solved!!!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- atlantamx3
HAHAHHAA---The COUNT!!
LOL.
And, Jarid, I think you are wrong too, BTW.
On my 92 RS, the hose she is speaking of was literally NOTHING (besides the resonator, of course). it went from the airbox to the resonator and had no other plugs or anything to it. No solenoids or anything. Just a big, dumb, resonator.
your 1994 RS may have been differnt since they changed the engine that year. Just a thought.
LOL.
Hahaha, count blah.
Perry, I believe the hose you are referring to is the hose that leads to a little resevoir for water or anything big to be drawn into. It is attached to another little plastic container from what I remember. I ripped mine out as it wouldn't have had any purpose with the drop in filter put in.
<small>[ December 12, 2003, 03:07 PM: Message edited by: 992mmx3 ]</small>
-Mark Lathrop
1992 MX-3 RS-T
B6T with some goodies
1992 MX-3 RS-T
Thanks for the replies yeah it is just a hose that is connected to the stock airbox the black box type thing that the hose comes from looks to be just some type of air inbox too but I hope my idea works thanks for all the help guys. Can always count on u's for info just in case u were wondering Iam a guy Theresa is my ladies name thanks again.
She's talking about intake before the airbox...Are you referring to the little hose that connects to the valve cover?Originally posted by cjthor:
No Sig
