BOV, injectors, fuel pump questions
I'm no real mechanic but can do regular maintenance. I'm want to learn more about my engine and have often wondered where to locate the BOV (Blow Off Valve) as well as the Injectors. I know some upgrade the injectors to the 1.8 Miata injectors but if they are bigger then what do I need to do for that upgrade and what is the benefit and gain from doing that?
Also, I would like to know more about doing the TurboXS BOV upgrade. Where can I find the parts I need for that and what all is involved?
For the WALBRO 255 FUEL PUMP, are there different types that I need to watch out for or are they all the same? Which Pump do I want and is it basically just a swap out for installation?
Any help and advice, thanks!
marshmallow15
Re: BOV, injectors, fuel pump questions
remove the unnecessary lighting on your car and then swap in a turbo motor, then try asking the question again.
how do diamond floor mats come in rolls?
- team slideways
- team slideways
Your car is stock?
You wont have a BOV, a BOV is one of the many Aftermarket parts you would need if you had a turbocharged engine, along with larger injectors and a larger fuel pump.
Unless your planning to do the B6T or BPT engine swap, or even a custom turbo setup on your stock engine, then you wont need any of the parts your asking about.
2004 Nissan Xterra - Daily Driver
2003.5 Mazdaspeed Protege - Sold
1994 MX-3 RS - Selling
Searching for a new performance car to buy, cant decide.
http://www.sounddomain.com/id/omenmx3
I'm going to try electronic ram air and a nitrous kit. It is suggested I upgrade the fuel pump to accomodate which is why I'm asking. If the custom supercharger doesn't work out then I will look into making a custom turbo. And this will all be done on my stock engine. The injectors sometimes stick and was wondering if the miata injectors will fit on a stock engine or not.
<small>[ December 08, 2003, 01:38 AM: Message edited by: Gkreator ]</small>
marshmallow15
not to be an *** , but im just going to save you some money. don't be stupid. do it right the first time. don't fall for that stupid-*** electronic supercharger crap. just paypal me the money instead of wasting it on an electronic supercharger. no you know what? go ahead and do it. i dare you.Originally posted by Gkreator:
haha does this mean that my hair dryer can add 50 hp to my car?
- team slideways
- team slideways
After doing a lot of reading up on the electric Bilge blowers, I seriously doubt they will work and therefore have decided to purchase a Zex dry nitrous kit and focus on the real deal. However I have already oredered the blowers so I might as well just experiment to see what the fuss is all about so I know 1st hand. I doubt I'll use the blowers after everything I've read, so it will be a learning experiment before I trash it. I'm more interested in making a custom turbo so any info/recommendations on that is a plus.
Manach
You seem like you are quite able to experiment on you side.. but might as well find some useful information.
Don't say you know about turbos before you haven't read Maximum Boost from Corky Bell. Buy it at Amazon.
Sad thing you have buy that electronic fan or blower. You might try it, but be aware that the plastic inside isn't resistant enought for the hot pressure that may be present.. The plastic might let go, and go into your engine.. (Ok ok, i'm not that good in english
If you want a custom turbo.. as a 1994 owner, you should have the 4 cylinders DOHC engine. You can bolt a 323 Manifold, and his turbo..
So some searches in the Force Induction forum..
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
[quote]Originally posted by Manach:
I have a TurboXS Type H BOV for sale
Brand new.
