brake upgrade for a 4cyl???
94mx3rsr
Post by 94mx3rsr »
Hi
I own a 94' mx3 w/bp turbo.....
I have done most basic mods...springs, struts, vented disks, good pads but I definately need more than that to slow me down.....they have too much fade!!!!!!!!!!
I am looking for a brake upgrade that could be cheaply done.....or relatively cheaply since i have no money for expensive big brake kits....i was wondering if it would be possible to pick up lets say millenia calipers and swap them on.....
what are my options....????
and for the rear...is the drum -> to disk conversion relatively simple has anyone done it????
thanks
j-m
Jean-Michel Basque
STOCK BPT @ 8.5PSI
3 RUNS ON THE 1/4 = 14.85 @ 96
papa roached
Re: brake upgrade for a 4cyl???
Post by papa roached »
the rear to disk is a bolt on as long as you got everything, i got the whole rearend from a GS for mine, you would also need a new master cyl for the swap, but its all bolt on, to bad the hurricane killed my RS before i could do it
<img src="http://images.cardomain.com/member_imag ... 0_full.jpg" alt=" - " />
<small>[ October 20, 2003, 10:23 PM: Message edited by: papa roached ]</small>
cjthor
Post by cjthor »
you dont need the ENTIRE rear end outta a GS for the rear disc brake swap. Just the spindles, brake hoses, and Ebrake cable. U can keep the old master cylinder..it will work....but not to the full potential.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
papa roached
i know you dont need it all, i got the whole rearend because it was $175 for it and i got the tie bar too, i just didnt wanna have to pull it all apart
