Hi all.
I have a '94 Mazda MX-3 1.6 four-cylinder with engine oil seeping
from between the engine- and transmission casings which leads me
to suspect that the crankshaft bearing seal has perished. (It just hit the 150000 mile mark.)
Is it possible to replace the crankshaft bearing seal once the
transmission has been removed or will I have to split the crank-
case to achieve this?
Thanks in advance,
Bjoern
Oil leak on my MX-3
OsoSlo z28
Re: Oil leak on my MX-3
drop the tranny, remove the flywheel, and you'll have no problems getting the rear main seal out.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
jlcg03
Ok remove your Transaxle/Transmission assembly (if you have a manul clutch remove the clutch/flywheel assembly, Automatic remove flexplate-to-crankshaft bolts, flexplate and shim plates) Now just cut the seal with a knife and install a rag to the house, then take a screwdriver and pry the seal off. Clean the housing real good and put on a new one. If you have any more questions you can e-mail me if you like. Have a good one.
<small>[ October 20, 2003, 06:49 PM: Message edited by: legend ]</small>
http://www.cardomain.com/memberpage/438427Sleep is just an encovinience. The answer to all questions more horse power.
Thanks for the replies, guys. I'll have my work cut out for the next couple of days.
Bjoern.
Bjoern.
OsoSlo z28
where in florida are you?
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
