Hi, trying to install new drive shaft and had trouble getting the old one out as well, the new one will only go part way and there was a burr on the collar going into the transaxle , dont want to force, i had removed the clip just to make sure that was not it..and removed the burr...worse case.. can the outside trasaxle housing come off,while in the car and may replace this part that is there before the splines,
HELP AND IDEAS NEEDED, THANKS
cv joint will not go in to manuel transaxle
Re: cv joint will not go in to manuel transaxle
I just replaced the clutch on my car, with the help of my dad. Obviously, HAYNES does not make a manual for the Mx-3 but they do make one for the Ford Probe/Mazda 626 and Mx-6, so i got that, since the Mx6 and Mx-3 are about the same.<p>You have a big problem here. If the shaft goes in halfway, then you will most likely have to disassemble the transmission. The Manual said that when removing the drive shafts, a socket that is nearly the same diameter as the toothed portion of the drive shaft (that goes into the transmission) should be inserted into the cavity, to prevent the gear that is on the inside, from dropping. If the shaft will not go in, ,then the gear has dropped. To make sure, look into the hole, and see if you can see a cylinder that has grooves in it (that mates with the grooved portion of the drive shaft which is the far half.) If you cant see it, or if it is not aligned with the smooth portion, you'll have to disassemble the transmission. Get the haynes auto manual for the mazda mx-6, it will help you a lot. I used this guide to replace the clutch, and it was a great help.<p>If you dont have time, take it to a shop. My dad and i started monday, and we got everything back together today.... except the fact that we messed up the tie rods, so we're waiting on those, so the car should be on the pavement mid afternoon tomorrow. i'm so excited.<p>Mike
