REVERSE LIGHT AND CLUTCH PROB'S
HEY CAN SOMBODY HELP I JUST SWICHED MY CLUTCH ON MY '92 MANUAL 4cyl AND MY REV LIGHTS DON'T WORK NOW.AND WHEN EVER I'M AT A LIGHT AND I'M ON 1st GEAR WITH THE CLUTCH ALL THE WAY DOWN IT STARTS GOIN FRONT AFTER A MINUTEOR TWO. I ALLREADY CHANGED THE BRAKE BOOSTER AND MY CLUTCH SOMEBODY HELP PLEASE!!!!!!!!!!!!!!!! ![Sad :(](./images/smilies/icon_sad.gif)
![Image](http://images.cardomain.com/member_images/7/web/379000-379999/379944_3.jpg)
Re: REVERSE LIGHT AND CLUTCH PROB'S
With the reverse lights: You probaly disconnected the sensor when u took the tranny out, just reconnect it with the harness. With the clutch...i have no idea, when i changed mine in the same car it worked beautifully. Maybe you installed something incorrectly, which would suck since you would have to take the tranny out again. Good luck man.
My Cardomain site
My Cardomain site
I cant telll u exactly, but its somewhere on the bottom of the tranny. Reason i know this: I did my clutch myself too, and in the process i ended up breaking the wire to the rev sensor and it didnt work, so i checked it out and discovered the problem. If you look at the tranny you will see it, it's just a sensor thing that is threaded into the tranny.
My Cardomain site
My Cardomain site
