stock clutch
stock clutch
would the stock cluch could scrach till 2 or 3 gear??
Re: stock clutch
that is kinda a iffy question. Yeah i imagine so given enough power from the motor and realllly cheap tiers..
-torp.
I don't own a Mazda.
Re: stock clutch
I would say most likely not. Unless the clutch is brand new and you had horrible tires on while it was raining. Try it though and see what you can do.
Re: stock clutch
scratch meaning peel?
lol i can squak 2nd on occasion if i catch it...
i get 2-3 second peels in first :s
Car Out Of Order For Now...
2 weeks In counting till re-incarnation!!
New G-Force Front Bumper!!
-_-_-_- Pics On Site -_-_-_-
http://members.cardomain.com/mx3_junkee
Re: stock clutch
yea i have 1993 mx-3 all stock and i just bouth a brand new stock clucth and would it erk lik in 2 or 3 gear??
Re: stock clutch
If you bought a brand new clutch you should not be trying to chirp gears anyway. It is very easy to do but the clutch needs time to break in. Take it easy for a while on it.
Re: stock clutch
and doubtful u will chirp 3rd
Re: stock clutch
if you clutch it, it will. oh, but that is bad
Re: stock clutch
I am running a BPT and I spun the tires straight thru first and second without trying. The BPT is faster then I thought it would be and I amvery happy with it. I would recommend it to anyone.
Re: stock clutch
I just finished changing the clutch on my 92 rs with a little help. I've only had the car on the road for 5-6 months, so I'm re-learning how to drive it. It is a stock clutch replacement and will chirp a bit if I let it out the Slightest bit too fast.
Try taking it out on dirt where you won't wear the tires as much and get used to the new clutch. It's cheaper than new tires.
...BTW, I have pictures of the inside of the bellhousing and the bay with the flywheel out in the open.
I'm new, but I had a good mechanic helpin' me so it wasn't to bad. If anyone needs info on re'n're a rs clutch, I would be more than happy to email them.
No Sig
Re: stock clutch
can any body tell where can i get coilovers for 1993 mx-3???/
