properly resetting the ecu
maxx
Post by maxx »
I searched the forums for how to reset the ecu. I've found so far 3 different ways.<p>1 - Disconnect the negative terminal, hold the brake for 15 seconds<p>2 - Disconnect the negative terminal, hold the brake for 30 seconds<p>3 - Disconnect the positive terminal for 15 minutes<p>Which way is the correct way to do it?<p>[ June 24, 2003: Message edited by: maxx ]</p>
Marlon
Re: properly resetting the ecu
Post by Marlon »
all are right, some are just quicker then others
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
swifty..
Post by swifty.. »
Check engine light??<p>96 MX3 4 cyl had bad spark plug and now Check Engine light is on.<p>Do you reset ECM to cancel light??<p>appreciate a reply to fix this.......<p>thanks.
swifty..
Custommx3
Site Administrator
Post by Custommx3 »
to clear all your engine codes, yes, you reset the ECU.<p>[ June 24, 2003: Message edited by: Custommx3 ]</p>
Len-Dogg
Post by Len-Dogg »
Yes they are all correct. What pushing on the brake does it run all the electricity out of your car faster. Even when you disconnect the battery some energy remains in the system. So pushing on the brake lights up the brake lights, and thus runs this left over energy out faster than waiting for it to dissipate on it's own.
1995 Blaze Red RS 5sp. Manual, Pacesetter Exhaust, Custom CAI, 17" ADR Rims, Kumho Tires, Altezzas, GS Style Spoiler and Mud Guards, Neoprene Seat Covers, Aluminum Foot Pedals, Leather Shift Knob, Remote Starter, Blaupunkt Stereo and 5-disc changer, Pioneer Speakers, Amp, and Sub<p>http://www.cardomain.com/id/lendogg<p>http://www.msu.edu/~leonar40/Car.html<p>Image
mazda
Post by mazda »
how come the engine light is still appears appears
chill out
mx3man83
Post by mx3man83 »
Because whatever is causing the light to be on is still wrong. Fix it, clear the ecu, and the light will be off.
My Cardomain site
